VeeBlock
- Jan 15, 2013
- Northwestern USA
I work in a job shop that sees just about anything imaginable come through the door to be quoted. Much of it involves single parts that the customer wants modified,fixed or rebuilt. I have only recently moved into the role of quoting these walk-in jobs. I don't have too much problems quoting machine times close enough. But I do have problems deciding what methods and design are best. For example; I have plenty of manual machining experience making accurate parts, but not such a broad knowledge base when it comes to choosing the best type of bearing to use, whether or not to use a dowel pin vs. a roll pin, if a press fit is sufficient or does it need to be welded, when to use splines vs. key and keyway, when should a bolt pattern have a few large bolts or many small bolts?, etc.
I realize most of this knowledge comes from experience of seeing a lot of different part configurations; both successful and failing. I don't have illusions of learning this the cheap, quick and easy way, however, I have to think that there's got to be some reference books, pamphlets, videos, etc., that cover some basic elements (some folksy rules-of-thumb) of part design that help the quoting/design process without involving mind-numbing engineering formulas and extensive trial and error. Most of our customers aren't interested in paying for hours of engineering research in addition to machine time.
Does anybody know any good manuals, reference books, or websites?
I appreciate any leads.
