Quote Originally Posted by anonimasu View Post
thanks for the help!, i got a good idea about how much to charge for them it seems the cleanup will cost them more then the actual cycletime anyway. looks like 3-5 dollars per part is pretty sane + material cost..
for the poster that asked I have a pretty old slow machine (mondiale gallic 420), however at max rpm and fairly high feed for roughing and sharp tools(I have some seco polished aluminium inserts) they will be super quick anyway.
And you're talking a 20 second cycle time?
So on ''a pretty old slow machine'' your'e going to at the very minimum;-
Barfeed to stop
Turn two diameters for a total distance of 70mm.
Drill 50mm deep.
Tap in 50mm.
Reverse spindle
Withdraw tap 50mm
Reverse Spindle.
Part off
Either your CAD / CAM ? whatever system is tellin porkies, or you need to find a new dealer, cos something isn't right, and if you work on that time you stated you will make sweet FA / lose money.
