Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
Like Tree5Likes
Thread: Storage Container Machine Shop?
  1. #21
    adama is online now Diamond
    Dec 2004
    uk
    4,700
    My only comment is we have a 40' at work used for storage, its got some good lighting and would make very usable work space, my biggest gripe is the things so damn long, given the choice i would personally have a couple of 20' with a nice door in-between side by side. Would make for a lot nicer space and being 2 rooms, help keep the mess more contained from things like the surface grinder + mill that launch chips every were! Condensation is not a major i, but it does get plenty warm in the summer + cool in the winter. Never been any signs of rodents though, no way to get in as the original doors are a damn good fit!
    As is i currently work out of a single garage some 20'x8', bigger would be nice, but there's still enough room in there to make a comfortable living, just as sami says, work tidy and keep it organised.
  2. #22
    Limy Sami is online now Diamond
    Jan 2007
    Norfolk, UK
    9,216
    FYI You can get side opening shipping containers.
    SHIPPING CONTAINER 20 ft Side door SC4 :: £3750.00 :: 20ft to 30ft :: New :: CONTAINERS DIRECT
    A mate built a very nice shop out of 3 side door 40 footers.
    adama likes this.
  3. #23
    Gary E is offline Diamond
    Jan 2006
    Houston, TX
    5,332
    Quote Originally Posted by rj newbould View Post
    You need to read more carefully, Gary. I referred to a reefer, not a container. You are aware that a reefer is a refrigerated trailer and licensed aren't you?
    Trailer trash? That's kind of harsh isn't it? You consider that I'm trailer trash?
    I have commercial property. I've had a reefer here and currently a 40' container, both of them legal and appropriate.
    Ok, I missed the "reefer".... most posts in here refer to containers... and I looked at the map, and it seems your out in the country side and as you state in a "commercial" district.... I apoligise... but if that was a typical suburban area, many dont even allow a pickup to be parked in your own driveway... pickups with a biz name on them are verboten unless its the repair guy working on your home... Anyway, I again appoligise for the remark.
    How do you or anyone actually WORK in one of those things without the A/C going full blast ??
  4. #24
    rj newbould's Avatar
    rj newbould is offline Diamond
    Aug 2005
    Hernando, FL
    5,647
    Quote Originally Posted by Gary E View Post
    No problem.. If I was gonna use one as a shop, I'd have to insulate it. In a reefer, there's no problem. Mine used to be quite comfortable even on a summer or winter day. I miss it..
  5. #25
    moto367 is online now Aluminum
    May 2008
    Ohio
    99
    Quote Originally Posted by demoj21 View Post
    My bad i missed the loaded part to your reply. The one advantage i can see is no property taxs on a shipping container.There are guys around here who are using them for home shops and they work for them. I have one i use for storage and it is great for that but i think i would try to find a building to run out of if i was going to make a living with my shop.Later Jason.
    They started taxing these around here not too long ago. They now even tax the steel canopy/carports.
  6. #26
    Pattnmaker is offline Cast Iron
    Nov 2007
    Hamilton, Ontario
    438
    They are now requiring a building permit here to park a container in an industrial yard.
  7. #27
    Aug 2005
    Hernando, FL
    5,647
    Quote Originally Posted by Pattnmaker View Post
    Give someone a little power and it's sure to be abused.
  8. #28
    Dec 2004
    uk
    4,700
    Trust me in the uk the number of days there too hot with the doors open you can afford to have those off, probably not as valid a approach in Florida. Equally leaving the door open and having a gator walk in would some what put you off the task at hand :-)
    Would love a couple of side opening ones here, but no way can i do that in this location :-(
  9. #29
    rhinsen is offline Aluminum
    Feb 2009
    Mo,usa
    121
    I was searching the net for the same thing, and found this guy in West Texas that had 30ac. and wanted a weekend place. He bought 4-40 footers and a backhoe. Over a summer of weekends he prepped the site and placed the containers one on top of the other about 40' apart. He put trusses over the span,roofed it with tin and a leanto on each side. He then made one contaier into living quarters. By this time he was getting a divorce and needed a place to live. It was a 20+ page story and very interesting how he got it done.
    Rick
  10. #30
    Antarctica is offline Aluminum
    Jan 2007
    Annapolis, Maryland
    181
    Saw the same thing done by the town of vallejo at the marina about 10 years ago. The took three 40's and made three walls, put trusses over top and left the one side open for equipment. Things ground to a halt - I think they started the project and only well into it realized that they too, needed to abide by building codes. Brilliant. I liked the idea and have considered doing a smaller version with 20's, albeit a bit more off the beaten path to avoid the building code issue.
    Brent
  11. #31
    aaronvan is offline Plastic
    Jun 2011
    DuPont, WA
    22
    Nice shot. What lens did you use?
  12. #32
    aerodark's Avatar
    aerodark is offline Stainless
    Feb 2008
    Bothell, WA USA
    1,777
    That picture (in the original post) was pirated from the internet.
