Home Page Forums Blog Articles Videos Search Register Advertise
Go Back   Practical Machinist - Largest Manufacturing Technology Forum on the Web > Manufacturing Today > General New
General New General metalworking, machine tool, and woodworking machinery discussions
Reply
Thread Tools Display Modes
  #1
Old 10-30-2009, 06:34 PM
ulyscol ulyscol is offline
Default 1095 steel help
Looking to make a bent spring clip out of 1095 spring steel 3/4" wide x 2" long by .022" thick. I need to make a 25 degree bend 1" up the length and I am looking for advice on how to form this. I can get hardened and tempered 1095 from McMaster but not sure if it is able to be bent? Any help would be appreciated.
  #2
Old 11-03-2009, 07:02 PM
Default
FYI for anyone interested. I was able to form the clip mentioned above using a 1/4" bend radius. At first I tried hot working it, but no matter what I did it kept annealing the metal. I experimented a little more and found at a 1/4" bend radius I could bend the piece to 90 degrees. Anything less then 1/4" and it would snap almost instantly.
  #3
Old 11-03-2009, 09:23 PM
juergenwt juergenwt is offline
Default
ulyscol - Here is how to do it - from an old timer.
Cut your steel to size, round off all edges with emery - important!
Make your bend or form.
Now hang your piece from a wire - a paper clip will do - and use a propane torch to heat to a cherry red. Quench in oil.
On the same wire- over a soft flame, with the oil still on it - hold it into the flame untill the oil burns - than quench. Repeat this for five , six or seven times. Heat -quench and you will come up with a perfect spring. Nice and shiny black. Test it and you will be surprized as to how good it is..If it comes out to soft - you heated it to much. A little practice makes perfect.
In the old world this is called tempering.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Forum SEO by Zoints
Ad Management plugin by RedTyger
