Home Page Forums Blog Articles Videos Search Register Advertise
Go Back   Practical Machinist - Largest Manufacturing Technology Forum on the Web > Manufacturing Today > General New
General New General metalworking, machine tool, and woodworking machinery discussions
Reply
Thread Tools Display Modes
  #1
Old 11-03-2009, 12:27 PM
Sean in CT Sean in CT is offline
Question 550 volt motor VFD
I just bought a Pullmax metal forming machine. It has a 550v 1hp 3phase motor. I have 208 3 phase power. Found a 208v 3 ph motor at www.surpluscenter.com for <$150 which is OK, however....
I was speaking with a friend who does a lot of fabrication on custom and classic cars. He has a VFD on his pullmax which he uses to slow the machine down, especially when making louvers and similar parts.
SO...
Is there a VFD available to run my 550v 3ph on 208 (single or 3 ph?)
or would i need to get a 208 3ph motor and a VFD?
or would i be best off to find a 2 speed 208 3ph motor?
thoughts? Ideas?
TIA
Sean
  #2
Old 11-03-2009, 12:44 PM
Frederick Harvie Frederick Harvie is offline
Default
You have two options
one is to get a transformer to transfrom your power to 550v and then use a 550 volt vfd. The transformer is a common item in Canada as 550v and 208 are both common voltages .
The second is to get a 208 motor and 208 VFD
Either option would give you far more controll then a 2 speed motor.
  #3
Old 11-03-2009, 01:18 PM
L Vanice L Vanice is offline
Default
You can find a 208V motor on eBay for a lot less than $150. I bought a NIB $800 list motor for $1 once, and paid another $65 for shipping, just to give you an idea of what might be available. Of course, I bought my VFD's on eBay too, for much less than retail.
To be effective with a VFD at low speeds, you should start with a more powerful motor. If the original motor is 1 HP, then I would use a 2 or 3 HP motor with VFD. You see, if you slow the motor to one half its nameplate speed, you reduce its power to one half its nameplate power. So a 2 HP motor will still have 1 HP at half speed.
There is no point in using a two speed motor with a VFD.
Larry
  #4
Old 11-03-2009, 03:56 PM
Default
Thanks for the input
i said 'screw it' and bought a motor b/c there were only 2 left and the price seemed reasonable. i didnt see any great deals on ebay
https://www.surpluscenter.com/item.a...tname=electric
Ill try it out and add a VFD if its too fast
thanks
sean
  #5
Old 11-03-2009, 04:32 PM
JoeE. JoeE. is offline
Default
I worked at a big sheet metal shop for a long time. It had a big Pullmax machine. Can't remember exactly what model number. It was a big machine. We called it a nibbler. Cut 10 and 14 gauge by the ton.
What I remember about it was the difficulty in setting it up for use, adjusting the cutting tools and stroke.
One man usually ran it, and if he was gone the usual results were no output from the machine cause of the difficulty in set up.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Forum SEO by Zoints
Ad Management plugin by RedTyger
