Go Back   Practical Machinist - Largest Manufacturing Technology Forum on the Web > Specific Machine Forums > Deckel, Maho, Aciera, Abene Mills
Deckel, Maho, Aciera, Abene Mills Discuss European "Deckel type" mills. Abene too !
Reply
Thread Tools Display Modes
  #1
Old 11-03-2009, 08:00 PM
jwatts jwatts is offline
Default FP1 coolant pump?
I recently picked up about a 1972 fp1 and have a question about the coolant pump and I'm a little confused after looking at the manual.
On page 11 "To turn the coolant pump on or off, turn the control knob 9 to the right or to the left, respectively."
On page 12 "...render the pump inoperative by turning control knob 9 to the right to disengage the clutch."
Which is it? I realize I will know soon enough once I get it wired up, but that may be a few more weeks.
  #2
Old 11-03-2009, 08:57 PM
bcstractor bcstractor is offline
Default
Don't need to wire it up - just turn the black wheel at the back with the door open at the bottom.
Chris P
  #3
Old 11-04-2009, 09:09 AM
wrench wrench is offline
Default
So, in summary... The pump is purely mechanical. It is one of the few things in the I don't think ever changed on the machine over the many years it was produced. I also suspect that only 5% of the people that have the machines now actually use coolant so it is probably academic....
Anyhow, you'll be able to figure out which is on easily.... ONe will rattle, the other will not!
Alan
  #4
Old 11-04-2009, 09:28 AM
Default
Thanks guys, that's easy enough. I was just a little suprised that the manual contradicted itself on the oposite sides of the same page.
Reply
Thread Tools
Display Modes
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forum SEO by Zoints
