Go Back   Practical Machinist - Largest Manufacturing Technology Forum on the Web > Manufacturing Today > Abrasive Machining (New Forum !)
Abrasive Machining (New Forum !) Discuss grinding and abrasive techniques and machines
Reply
Thread Tools Display Modes
  #1
Old 11-03-2009, 12:57 PM
buckeye buckeye is offline
Default Honing on 6061
Greetings all.
I need a .723" bore +/-.0005 in a piece of 6061. Im considering drilling 23/32" (.7188") Then finishing to size with the hone. Would it be possible to rub out all the drill marks and leave a smooth finish with .0042" honing allowance?
Buckeye
  #2
Old 11-03-2009, 01:01 PM
Conrad Hoffman Conrad Hoffman is offline
Default
Maybe with a reamed hole, not sure about drilled.
  #3
Old 11-03-2009, 01:21 PM
V Semionovas V Semionovas is offline
Default
I don't have much experience with honing, but I believe aluminium is too soft to be honed, wont the abrasive grains get inbeded in the metal?
how about pushing a bearing ball tru it?
Vladimir
  #4
Old 11-03-2009, 02:22 PM
Default
you can buy the correct stones, just not sure if it will be enough material to clean-up.
  #5
Old 11-03-2009, 08:04 PM
Ken hosford Ken hosford is offline
Default clean up
There is a cart some wear on probable hole size from drilling . I would say no it is probably not stock left to clean . unless you do not need 100 % clean . I agree a reamed hole yes . Ball broaching maybe
  #6
Old 11-03-2009, 08:33 PM
Davis In SC Davis In SC is offline
Default
A few years ago, I built some "Short Run" molds from 6061-T6511. There were quite a few ejector pin holes that need to be sized to a snug slip fit for the ejector pins. I carefully located, spot drilled and reamed these holes at .002 under, and then honed them using a standard Sunnen stone that is used on steel. I used very low out feed pressure, and copious flow of oil. Holes came out perfect, molds are still running , long after ther should be worn out.. Just be careful not to damage mouth of hole as hone enters.. HTH
  #7
Old 11-03-2009, 08:38 PM
Default
Thanks, this too is a short run, but I need a truly round profile and a good SF. Boring would probably work, but the powers that be refuse to buy the proper tooling, and I dont have the time to make it myself.
  #8
Old 11-03-2009, 08:45 PM
split tenth split tenth is offline
Default
I would leave about .010 per side.Rough with a coarse stone,finish with a finer stone.The stock will come out fast. Use a lot of oil.Check for stone loading.Open up the stone with the diamond dressing tool that comes with the machine.The part will heat up fast so watch the temperature if you're trying to hold .0001.You did not mention the bore length.The hone likes a long bore,does not like a short one.
  #9
Old 11-03-2009, 09:50 PM
Default
Quote:
Ok, the next drill step down would be to leave .018" diameter. The bore is about 5.950" in length. What grit stones would you use to rough and finish? I would like something near a 20 micro-inch finish.
  #10
Old 11-04-2009, 09:08 AM
gappmast gappmast is offline
Default
Honing aluminum is not problem you will want to use an silicon Carbide stone. Use a 220 grit for stock removal and it will give you about a 50RA finish. 280 grit will give you a 33 RA and a 400 grit will get you to about 16RA.
As for stock needed to hone it depends on how well your drill cuts. If you have a good drill and it does not wander (bannana shape hole) .010 on diameter should be more than enough. If the drill tears or wanders you will need more.
Don't worry about inbedding grit aluminum is honed all the time with no problem.
Reply
Thread Tools
Display Modes
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forum SEO by Zoints
