Go Back   Practical Machinist - Largest Manufacturing Technology Forum on the Web > Manufacturing Today > CAD / CAM
CAD / CAM Computer aided design/ manufacturing software issues
Reply
Thread Tools Display Modes
  #1
Old 10-27-2009, 06:53 AM
mostagear mostagear is offline
Thumbs up Variable pitch rotary (nice video)
I want to share this video.
http://www.youtube.com/watch?v=Th97I...eature=channel
i wonder what's the easiest way to make such workpiece (with variable pitch).
i tried doing similar work,i used simple hand written program. it was ok. but the pitch was fixed.
in general, 'm using edgecam for rotary works. but for screw like, i make it manually.
  #2
Old 10-27-2009, 08:24 AM
jabezkin jabezkin is offline
Default
Video? I don't see no stinkin' video.
  #3
Old 10-27-2009, 10:16 AM
Default
sorry,
link added
  #4
Old 10-27-2009, 10:24 AM
Default
Quote:
Originally Posted by mostagear View Post
sorry,
link added
Yippee!!!!!!!!!
Nice video, thanks.
  #5
Old 10-27-2009, 06:25 PM
HuFlungDung HuFlungDung is offline
Default
That sure is a growly old indexer
I wonder if that is a variable pitch helix, or is it two constant lead helices, one with a longer lead than the other one? The fact that the land between the two grows uniformly wider along the length is what makes me think this might be the case.
  #6
Old 10-27-2009, 09:09 PM
John Welden's Avatar
John Welden John Welden is offline
Default
The trick is to hold a 2x4 against the part.
  #7
Old 10-28-2009, 01:06 AM
Ghost Ghost is offline
Default
Anyone know what the deal is with that piece of wood?
  #8
Old 10-28-2009, 04:42 AM
Default
Quote:
What wood? Oh, you mean the backlash elimination device?
  #9
Old 10-28-2009, 08:34 AM
Default
i think that piece of wood is for damping, to avoid workpiece vibration while cutting
  #10
Old 10-29-2009, 10:41 AM
spork2367 spork2367 is offline
Default
We cut pieces like that all the time. They are typically used in the bread making industry to feed dough. (although I'm sure there are a million other uses) We run ours the same way (minus the 2x4). I think he is wedging the 2x4 underneath to keep it from flexing. We have the same problem only worse since the screws we run are 6-8 ft. long. We made special trays that go underneath with screw jack adjusters. I'm going to suggest for time savings though that we switch to the 2x4 method. Maybe a 2x6 for our larger items.
  #11
Old 10-29-2009, 06:02 PM
scudzuki scudzuki is offline
Default
Looks like a screw for an extruder.
The wood is to dampen harmonics probably.
Joe
  #12
Old 10-31-2009, 04:24 AM
Default
Quote:
thanks spork2367
but what the 2x4 method refers to , as well as 2x6??
what software do you use?
  #13
Old 11-03-2009, 09:30 AM
Default
thanks spork2367
I was joking about the 2x4 and 2x6. He was likely using the wood to stop the piece from flexing down. We use a custom made tray with adjustable screw jacks to support the bottom of the part. Ours were programmed in mastercam and run on an old Fadal.
  #14
Old 11-06-2009, 09:23 PM
curtrnev curtrnev is offline
Default
Maybe the wood burnishes the edge?
  #15
Old 11-06-2009, 09:29 PM
bryan_machine bryan_machine is offline
Default
mostagear - 2x4 and 2x6 are standard (in inches) dimensions for lumber in the US. Our houses, for example, are framed with 2x4's and 2x6's...
I imagine in Egypt you buy wood sized in metric units....
  #16
Old 11-07-2009, 07:55 AM
gatz gatz is offline
Default
Agree about the combined different pitches as opposed to "variable" pitch.
That's certainly not a 2x4...more like a 1 x 4 (3/4 x 3 1/2) or thinner, could be a slat from a pallet.
Don't know what other countries use for "standard" finished dimensions of wood products.....
U.S. system may seem very strange to others.......along with most everything else we've standardized.
My guess is that the wood is used to eliminate or reduce chatter. Can't see that large a diameter for given length material flexing enough to cause problems; although spork2367 has a somewhat different scenario and, as he said, would serve to avoid flexing.
Reply
Thread Tools
Display Modes
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forum SEO by Zoints
