northernsinger
- Aug 19, 2004
- New England
We discussed here recently (http://www.practicalmachinist.com/vb/showthread.php?t=149446) the topic of historic machine shop lighting.
While I don't seem to have photographs of this exactly I do have here two photographs, each taken November 5th, 1941, at my family's part-owned iron works, The S. J. Creswell Iron Works, in Philadelphia (my family bought into this later, not until 1952) that show lighting in two areas of the plant.
Here is a scene identified as the 'engineering dept,' a space I always knew in the 1960's as 'the drafting room:'
You can quite easily see the green and white reflectors we were discussing. I wasn't in the drafting room all that much but, in this view, at the right, you can see into the pattern shop where I did spend some time. I think that the band saw is just about visible through the glass, encased in shop built shrouds. (The band saw shared a countershaft with the 20" jointer, which was under the floor beneath the two machines, this was a second floor loft.) Nine people, one of whom might have been the business owner, a lot of work going on there.
Here is a photograph of the offices:
in which you can quite easily see the fluorescent fixtures that were de riguer at the time. Seven people to run that office. There was also a president's office, and maybe a little spot for a paymaster; later I recall there was a spot for a purchasing agent. I was in the offices a good bit and, when I was there about 25 years later they looked very similar to this photograph. Cute secretaries, if they are alive the youngest will be in her late eighties now.
Fashion statement, November in Philadelphia: nine of the eleven men are wearing vests.
Too bad it couldn't have been saved as a museum; it's a parking lot at the moment, with development plans proceeding.
