mfisher
- Oct 24, 2006
- Annapolis, Maryland
A friend was changing the exhaust mixing elbow on a Yanmar 2GM. One bolt broke off on removal, but had severe corrosion (crack?) causing that? Cast iron riser, broken piece rusted in.
Bolt is m8x1.25. A2-70 (304 stainless).
Other than the normal issues of 304, any additional issues from the corrosion or some thermal cycling? Water cooled exhaust, so it hasn't gotten that hot.
Will try one of the other bolts for drilling first, but looking for any other suggestion before drilling in to the broken one. Good access to drill.
Broken flush,prefer not to try to weld a head onto it in place. Enough material on the riser to tap oversize if needed.
Thanks in advance.
Thanks in advance.
