Forestgnome
- Aug 2, 2008
- Californeeeah
Wondering what your experience is. Do spring loaded edge finders work on inside/outside curves, or is there error beyond what you'd get on a flat surface?
I guess I didn't know I wasn't supposed to use the edge finder to find the center of round work.
My method is:
1. Find a point near the centerline of one axis, X for this example.
The operative word here is near, within .1" on 3/4" stock is close enough.
2. Touch off Y and zero both axis of the DRO.
3. Move only Y to the other side of the part and touch off, the other axis must still be 0.
4. Calculate the mid point of the measurement and position Y to that value and zero the Y axis.
5. Repeat steps 2-4 for the other axis.
If you aren't sure if you are there, touch off the 4 hits from center, are you close enough?
Most of the time I am within a couple of thou, and the time to do this is much less than setting up an indicator
Most of the time I am within a couple of thou, and the time to do this is much less than setting up an indicator.
Many of the newer "machinists" really don't know how to make good use of the spring loaded edge finders or "wigglers". Many that I show this method, and the proper use of the tool, stare in amazement at how easy it is.
Bill
Most of the time a couple tho is out of tolerance for precision work...Newer machinists probably just know that an indicator in a drill chuck is just as fast as an edgefinder...and more accurate...there is no replacement for seting up your part with the best method possible...How much time do you save when you relize your "a couple tho off" and you have scrapped a part and now have to adjust and run another(possible scrap) part? If you take the extra 30 seconds you can indicate to .0001 and have location dead nuts...what you said i can really only see working in wide open tolerance +\- 1/32...anything else your just wasting time
Thanks Tay. Next time I'm trying to run a job with tolerances of .0001, I'll ditch the collet and just throw my indicator into a drill chuck. I learn something new every day.
Like he said, some people just simply don't know how to use an edge finder...
I guess to each his own.
I should clarify. Imagine a rectangular box where one wall is curved. You need to find the edge of the inside of the curved wall. You're already on the center of the arc. The arc has radius of 1". How do you do it? In the case of finding the center of a hole absolute accuracy isn't critical. You can find the center as long as the error is consistent.
in this case if you are already on centerline one way then yes u can touch the inside radius and then move to center...WAY different than finding the center of a complete circle when you have no absolute starting point.
But in the case of finding center of a hole, accuracy is critical if your customer want your feature(bolt circle etc) concentric or even just in the right place...
Do you work in a shop where accuracy is not critical???
round these parts when you make something that goes in the air you damn well better be accurate
What I'm saying is that if your edge finder is consistently off by .005", you'll still hit the center of a hole with much better accuracy than .005". It's like bisecting a line with a compass. The compass isn't set for half the line length, it just has to stay at the same setting for each mark.
Notice
