Hi,
I am somewhat new to using hand drills to drill steel. I was using the drill speed charts and found that bits were getting hot enough to smoke heavy sulphur based cutting oil. As an example, I was trying to drill a 1/2" hole through ~ 3/16" thick low carbon steel at 700 RPM. The bits always caught at the end throwing the drill around and often chipping the bit.
After trial and error, I tried drilling much slower than the drill speed charts would suggest. The results were amazing. Bits seem to last longer and they don't bind at the end.
My theory is that its almost impossible to apply enough pressure with a pistol grip drill to justify the higher speeds.
I am wondering if my theory is correct.
If anyone wants to entertain me some more, I have been using air drills for this work. Most of the major players offer drills in 0.4, 0.6, and 0.9 HP. I am wondering why this is necessary for hand drills, because its hard to apply enough force to warrant all the power? Do you really need a 0.9HP hand drill? If it catches I would think all its going to do is try to break your wrist faster. But clearly folks like Sioux and Dotco make these for a reason.
Thanks!
Thanks!
