M.B. Naegle
- Feb 7, 2011
- Conroe, TX USA
Looking for some help Id-ing and sourcing a chuck for our TOS/ZPS R5 Turret Lathe. It was built in the mid-60's Soviet Czeck Republic with imperial dials (built for use in the states). The chuck's back housing is cracked so I'm on the lookout for new work holding possibilities.
I pulled the chuck off the spindle and apart. The back-plate is still useable but I'm trying to ID it's mount system in case it doesn't fit with a new chuck. Dimensionally it looks like a B2-6 size mount (short taper with holes through a flange to mount. no threads or cams to lock in place). But I'm not 100% sure. There are 6 mounting holes around the flange but they alternate threaded and unthreaded. The backplate we have had three threaded studs on the back.
I'm going to post some pics, but off hand, does anyone have experience working with these older ISO spindles? How big a deal would it be to make an adapter that uses something more current like a cam lock system? (we have lots of stuff for D1-4). A 3-jaw chuck and maybe a 4-jaw and 5c collet nose would cover everything we do.
I'm getting this lathe re-wired and cleaned up and have been impressed by how beefy and operator friendly it seems to be. No thread cutting capability but that's ok. All the work stops are easy to disengage for non-production engine lathe work. We had a heavy heavy knurling job a couple years ago and really could of used this lathe but it was in the warehouse and didn't have power run to it yet. Now it now has a piece of real-estate and power to call it's own, so I'm hoping it comes back to life so we can put it's Comm-y butt to work for us Yanks!
