Long Lonesome
- Dec 12, 2005
- Arkansas
The SB 9C lathe I recently bought has been fitted with a large 1/2hp, 110v motor. I happen to have a nice 1/4hp, 220v motor that I would like to use in order to solve a couple of problems.
First, the motor that is on the lathe now is so large, an adapter plate had to be used to shift the motor over for proper belt alignment. It sits behind the chuck. Second, I'm not certain that it can be wired for reverse, and my 1/4hp motor can. Also, the way it is mounted, the shaft oil cups point forward and down. It was suggested in an earlier post that I use offset oil cups, but I believe that they would still incline down, away from the shaft. My motor has rubber isolation donuts on the end bells where the mounting bracket attaches and can be rotated to allow the oil cups to face up. The isolation mounting may be a plus, as well, and the motor just "looks right" and fits right on the lathe - without an adapter plate.
The South Bend website recommends a 1/4hp motor for the 6-spd 9C.
Does anyone here feel that 1/4 hp would be inadequate, given that this lathe will be for hobby use only?
Greg
Greg
