1018 or 4140 for crossfeed?
Results 1 to 8 of 8
    Jan 2009
    belleville,il
    174
    52
    18
    Default 1018 or 4140 for crossfeed?
    In replacing my crossfeed lead screw. Do I want to use 1018 carbon steel or heat-treated 4140 alloy steel from McMaster Carr.
    Thanks Clay
    May 2006
    Grafton, Ohio
    58
    16
    1045 is in the middle of those 2. I use it for shafting and it's pretty tuff. JC
    Sep 2005
    Indiana, USA
    2,868
    52
    Definitely avoid 1018, if for no other reason than machinability -- it's soft and gummy. I would use 1144 ("Stressproof") for the screw -- moderately hard in the annealed state, stable, and machines like a dream.
    Paula
    Sep 2007
    Washington
    4,487
    84
    1015
    +1 for 1144SP. Besides being free-machining, it has good wear properties. I did a new crossfeed screw for my Logan, complete with integral feed gear, out of 1144.
    Regards.
    Finegrain
    Dec 2003
    Calgary, Alberta, Canada
    1,380
    81
    if you are buying acme screw stock, get the 4140.
    Jan 2009
    belleville,il
    174
    52
    18
    Default skill?
    Thanks guys I don't have the tooling (threading gears or threading dial) and mainly the skill to make the threads. So i'm looking at buying the precision acme threaded rod from McMaster. I wasn't sure if the heat-treat 4140 could be turned down.
    Thanks all for the info Clay
    Feb 2004
    Traverse City, MI
    3,260
    60
    102
    PM Swells and see if he has any in stock. The Amce LH screw he provided me for my cross slide screw had a much better finish than I could get by turning the threads myself. Gary P. Hansen
    Aug 2006
    Southwest, Alabama, USA
    475
    Quote Originally Posted by clay27bsouthbend View Post
    ....I wasn't sure if the heat-treat 4140 could be turned down.
    4140HT, from the mill, is 28 to 32 Rc in hardness. You can machine it without any problem..... Even with HSS.
    alg4884
