Thanks for the reply. I will get a photo tonight and post it.
I received two lathes in pieces from a friend cleaning out his storage spaces. He used to have a small business in machinery and rebuilding stuff. So I am making the best lathe out of two sets of parts. Both are cabinet drive 10K units. I only have the one apron however, and as I said, no holes for the selector. Funny, because it is complete and has obviously been in use. I cleaned it all and replaced the felts and such.
I plan to drill the holes, but I want to make sure they are located in the right spot. Neutral is easy. But I want to make sure I don't drill a hole in the drive position where the gear backlash is too tight. No adjustment after the hole is drilled. I'm also curious as how the unit kept the gears engaged without a detent hole. The gears would tend to push apart against resistance without a holding pin. Hmmm.
Thanks Again - John
