It has .375 bore, about 1" OD. The flange on my 10K cross-feed is bigger than this dial and the shaft is 0.500". My bad, I didn't take care and realize the differences between a 9 and 10k.
This 10K was cheap, a tip over and came with broken tumblers, wobbly carriage wheel and no cross-feed handles or dial. And no motor or countershafts.
I debated just parting it out but you know what happens when you start cleaning and looking at things, decided it wasn't that worn, and a better size for small stuff than a 28" Monarch.
Everything else is good now that its clean and oiled, it was just sticky from sitting in a barn. I swapped in a DC drive, 1hp motor and tach, found some tumblers, replaced all the felts, adjusted bearings. Bought an A size 40pos. Im in deep now. Just need a dial and handle or a pair of vice grips
It will be nice to have a small lathe around.
PS: don't know who Ted is
