weedy64
- Dec 12, 2005
- Langley, B.C.
The saddle gib, if I tighten the bolts its still loose and can clunk up and down (interupted cut). Other lathes I have seen have bearings on eccentric bolts in this area. What do people do with the SB, face mill the slide section and shim it for clearance ?
Large Compound and Cross-slide dials: Has anyone had these 3D printed and\or have CAD drawings of these parts they could share? I only have a compound dial and I find it tough to read, a bit too fine a pitch on such a small diameter.
I am missing a ball crank on the cross-feed or the compound not sure which they seem interchangeable. Are they or is one ball crank larger than the other as they have different p/n's?
