Outboardguy44
- Feb 4, 2007
- Harrow Ontario
I am working on a newly acquired South Bend, catalog number CL670Z with 3 1/2 foot bed, model number stamped in bed ways is DDB102KG. it will need to be worked on before I do any work on it, if that makes any sense...
anyway, I took the spindle out to find that there are no oiling wicks in the headstock. I'm assuming that is wrong. I'm also used to my 9A which does not have bearing inserts in the headstock to support the spindle, but this one does. I don't know enough about the 10K's to know if that's correct either. Whomever inserted the bearings in this headstock did not align the hole in the bushing with the felt wick bores. I'm not exactly sure how to proceed with this one.
Was considering pressing the bushings out and re-positioning so that they would allow the oiling wicks to a) actually be installed, and b) travel properly so they can do their job. Would be interested in hearing/seeing what y'all have to say about my spindle situation. FWIW I haven't measured anything yet WRT the ID of the bearings versus spindle diameter.
Thanks for any insight.
Best,
Chris S
Best,
Chris S
