StrayAlien
Cast Iron
- Aug 18, 2014
- Melbourne, Australia
Hi all,
I am attempting to make a gauge that apes the spindle for the 10L. I have some cast iron of unknown quality - cut from elevator weights. I am using cast to get some practice in for making some back plates - which will be cast iron.
I really am having difficulty getting it not to tear to hell when cutting a thread in it. Tool is a new brazed-on 60deg carbide that I have diamond-honed the nose down on to get a snug fit into the spindle thread.
I am cutting dry at the lowest speed back gear only taking 2-3 thou feed increments at compound with tool post at 29 degrees.
The only way I have managed to get a good finish on this material is spinning at about 700rpm and using a carbide tip. But I can't do that while threading.
Machinery's handbook says helix angle for 2.25" at 8tpi is just a little over 1 degree, so I figure the larger-than-one-degree angles on the tool will give enough clearance not to rub. (?)
Any hints? All help appreciated.
Greg.
Greg.
