13 or 16 inch compound ID needed
Results 1 to 8 of 8
    Apr 2005
    NY
    184
    20
    5
    Default 13 or 16 inch compound ID needed
    This came with a 9A I bought a few months ago. It sure looks like a newer South Bend part. I can't find anything on the casting numbers though. I want to put it on Ebay but need to ID it first. Can anybody help me?
    Attached Thumbnails Attached Thumbnails 20170613_103810.jpg   20170613_103821.jpg
    Sep 2010
    moscow,ohio
    4,406
    445
    1271
    measure the diameter of the dovetailed spud on the bottom
    But IIRC that c101 unit code says its a 10L compound.
    Jul 2010
    Virginia, USA
    3,155
    76
    506
    Given the 'T' on the underside of the casting, I'd guess it is from a 13?
    allan
    Sep 2010
    moscow,ohio
    4,406
    445
    1271
    This page courtesy of Steve Wells site.
    With this you can positively identify by looking at the diminisions of both the compound itself and the hole size in the compound rest base(AKA cross slide)
    http://www.wswells.com/data/spec_sheet/5224.pdf
  5. Likes Erich liked this post
    Apr 2005
    NY
    184
    20
    5
    It's big, much much larger than my heavy 10 compound or the compound on my 12" Clausing 5900
    Apr 2005
    NY
    184
    20
    5
    Next to my heavy 10 compound. That's a 6" scale. The dovetail hub measures 2 3/4"
    Apr 2017
    172
    20
    73
    The pdf that iwannanew10k linked to identifies the compound as fitting a 16 inch lathe.
    The dovetail hub 2.75 and the width of the flat on top of 4.5 inches (dimensions R and Y in chart)
  9. #8
    Apr 2005
    NY
    184
    20
    5
    Quote Originally Posted by Erich View Post
    I couldn't open that link in my metal building, but I think you are correct. Thanks guys
