13” compound ball crank retainer and dial thumbscrew specs.
Results 1 to 7 of 7
    Aug 2017
    Illinois
    91
    55
    29
    Default 13” compound ball crank retainer and dial thumbscrew specs.
    I recently acquired a 13” 145b that needs some love in the compound department.
    For lack of a replacement part source as of yet, I was hoping someone might be able to tell me the compound ball crank retainer nut thread pitch?
    EDIT The compound ball crank retainer nut is .555" diameter and 5/16-24 thread.
    Does anyone know the thread size used on the compound dial’s thumb screw?
    Thank you
    Feb 2008
    newark DE USA
    1,040
    84
    My T lathe SN 142442 has a 10/32 thread in that dial. The screw is a slot head set screw,not a thumb screw. A thumb screw might be good. Hmmm.
    Aug 2017
    Illinois
    91
    55
    29
    k3vyl, thank for the info. I believe the screw in my cross feed is slotted as well. I assume the missing compound screw would also be slotted. I informally called it a "thumbscrew" because the one on the cross feed while slotted is also knurled. At any rate I will try a 10-32, thanks.
    Feb 2008
    newark DE USA
    1,040
    84
    The ones on mine are set screws that are flush or below the diameter of the dial. They are tricky to loosen when facing down. I had a Logan that had nurled head screws on the dials,easier. There may be brass pads under the screws,I forgot to check that when I took mine out. Check the parts list in the stickeys.
  5. Likes John Strange liked this post
    Mar 2016
    New Jersey
    912
    16
    178
    Mine had one original slotted screw and one cobbled up mess put together from what looked like a machine screw with a nut soldered to it. I replaced both with a brass thumbscrew cut to length.
  7. Likes John Strange liked this post
  8. #6
    Aug 2013
    761
    450
    207
    Mine (both compound and cross slide) are knurled and have a screw slot, about an 1/8" thick head; looks original.
  9. Likes John Strange liked this post
  10. #7
    Aug 2017
    Illinois
    91
    55
    29
    Thank you all around for the bits of info and thoughts. Thankfully I managed to get my compound back in order.
