cvmikeray
- Nov 25, 2008
- Birmingham, Alabama USA
Well my search for a lathe (this time ) has ended with the purchase of a 1981 South Bend 13 inch machine with a taper attachment. It is a really clean machine and looks like it has been taken care of. Once I get it on the floor of my shop I will get some close ups of the various areas. It has one issue where the piece of the taper attacehment that hooks to the cross slide has been broken and repaired. But the repair looks to have been very well done.
Specs:
SOUTH BEND 13" X 42" CC ENGINE LATHE WITH TAPER ATTACHMENT
SERIAL NUMBER: 16725T
Catalog Number: CL145C
Approximate Year: 1981
Specifications:
Swing: 13"
Bed Length: 6'
Spindle Speeds IN RPM, 4 Step Pulley
Open Belt: 270, 418, 628 And 940 RPM
Back Gear: 40, 60, 90 And 135 RPM
Tailstock Spindle Nose: No. 3 Morse Taper
Spindle Nose: D1-4 Cam Lock
Thru Hole: 1 3/8"
48 Feed Ranges: .0015-.0841
48 Thread Ranges: 4-224 TPI, ON Quick Change
Gear Box
Equipped With:
Taper Attachment With Bed Clamp
Flame Hardened Bedways
Cushman 6" Diameter 3 Jaw Scroll Chuck
Chuck Guard
Graduated Hand Dials
Micro Adjustable Stop
Four Position Tool Holder With Z Cutters
Live Center
Dead Center
Wrenches
Under Carriage Motor Design
Start/Stop, Forward/Reverse Push Buttons
2 HP, 220/440 Volt, 1730 RPM, 3 Phase Motor,
(Currently Wired For 440 Volts)
Specs:
Specifications:
Swing: 13"
Bed Length: 6'
Thru Hole: 1 3/8"
Gear Box
Equipped With:
Chuck Guard
Live Center
Dead Center
Wrenches
