Hi,
I read somewhere in this forum it is a good idea to clean, inspect and re-felt before you begin using your lathe. That made sense to me. This early war 13" is in pretty good shape!
When I removed the spindle bearing caps (no brass) I saw these little spring clips in the v-groove on both sides of the small and large caps. I removed the old spring loaded felts out of the reservoir (still trying to get all the old oil out of the reservoirs).
Anyway, I noticed the thrust roller bearing in the small side wasn't lubricated to my satisfaction. Are these 4 clips for retaining felts? Does oil wick through via these little clips?
I couldn't find anything about them in my manuals and I want to understand it and put it back together correctly.
Thanks!
Thanks!
