dcstang1967
- Feb 24, 2014
This spring i was in the process of retrofitting a heavy 10 qcgb onto my 1918 era change gear lathe. the project has been on hold until now. I need an 18dp idler gear of any size so that the heavy 10 banjo will reach the screw gear. I will be making a bracket to hold this idler and it will be mounted off of the side of the headstock. Let me know if you have anything. The bigger the better. Thanks
