jordankstoner
- Mar 22, 2017
A little background: I purchased this south bend from an older fellow. He is friends with my father who told me he had a lathe. I showed interest in it and he sold it to me for $1100. Some of the gears had missing teeth but I have replaced them and I also had to replace the motor so I think the price was fair being that I knew I still had to spend more money on it.
To the meat and potatoes: If I chuck up a long piece of metal stock in it, at the very end of that stock work you will notice a slight wobble as it is rotating which ultimately means it isn't running true... obviously. I replaced the 6" atlas 3 jaw chuck with a brand new 7" south bend 3 jaw chuck that cost me a little over $700. After that the wobble became far less dramatic but was without a doubt still there (so this was still a good buy I figured because the chuck needed work done to it replacing anyway). After reading through posts on this website, I became aware that it may be my brass bushings on the headstock causing the wobble, and have come to the conclusion thats exactly what it is. After taking the headstock apart, the first thing I noticed were shims in between the two halves of the bushings that clamp the spindle in place. I read that wear on these 1920-1930 model bushings are a common problem that cause the work to stop running true. If I grip the work stock and lift up you can definitely feel the play in the bushings closest to the chuck. This was confirmation for me that the wear on the bushings was to blame. However, I never could notice it on the other side, but I am sure it is there as well. Ever since I decided that this was the problem a year ago, I have since purchased from of eBay 2 different headstock castings (making a total of 3 castings and 7 pairs of bushings), one of which was an entire headstock assembly (just to ensure I had enough parts) and two spindles (well only purchased 1 spindle but ir is now a total of 2 that I have), all which were very hard to come by. I'm experimenting with the second headstock casting right now. It has play in it as well. The last one has an extra pair of bushings and seems to be in better shape than the first two. I am hoping I will get lucky and one of the pairs not have so much wear but I am not very optimistic. Aside from making brand new bushings, what in the world can I possibly do to fix this "wobble"? I just do not see how shims can be the answer. Wouldn't shims cause more of a gap, and more play? Any and all suggestions/advice for me would be much appreciated.
