This is my first lathe purchase. (well technically 2nd, I got an Atlas/Clausing 4800 in great shape the same week that I don't have leveled and running yet.)
I picked up a 1937 - 15" x 5', Catalog #: 114B for a very reasonable price. It was under power when I looked at it. It runs quite, no gears are damaged. It is 3ph so I have to get a VFD to run in my garage. It is an under mount motor but is not a factory base. Might be original motor, not sure.
Photos here: Photo Index - South Bend Lathe Works - 15"x5' Cat No: #114B | VintageMachinery.org
The biggest issue I think is bed wear. The ways are worn. Using a straight edge clamped on the right side of the front way. On the side facing the operator, it was about .015" and the back side was about .010". There is some scoring. The back way is less than .010" on both sides.
Is it even worth the work to clean up an use?
What kind of wear is normal for an 80 year old lathe?
Thanks so much for the help. I have already learned much from this forum.
