Assuming you have a model 5 type(405,415...) with the single locking bolt...
Once the bolt is out, there is a shoe under it, squirt some good penetrant in there and use a hair dryer or similar to warm the cross slide to help it wick in..then it's just careful working it around and gentle tapping...it helps to remove the cross slide and place it up side down on a couple supporting blocks and tap directly on the compound spud underneath, give it a couple taps,swivel compound,tap,swivel..tap,swivel..
You don't want to keep tapping with the compound in the same location or the shoe can dig in and ding up the compound spud....
Do a google image search for south bend 9" compound to see the spud shape and you will understand how the shoe bears on it...the shoe is just a round pin cut on the end to a shape that mates with that spud.
