3 jaw chuck
Results 1 to 10 of 10
Thread: 3 jaw chuck
    Apr 2009
    adamsville alabama usa
    20
    Default 3 jaw chuck
    I need to replace the jaws on 3jaw cushman chuck,or they are new jaws available. The model is 5340b, if not what is the best way to regrind or rebore the inside faces of the jaws. I have also noticed that some of the companys say they can rebuild them, anyone used this service before please help TOM
    Jan 2005
    Salem, Ohio
    4,104
    47
    88
    Cool
    Never used them but they aren't too far from me...Bob
    http://www.worldwidechuck.com/
    Bob Wright Metal Master Fab
    Salem, Ohio Birthplace of the Silver and Deming Drill, all others are copies.
    Jul 2005
    NE Ohio
    517
    Tom
    Not to rain on your parade but it's usually cheaper to buy a new Bison chuck then have and old one rebuilt. I'm not familiar with the Cushman you have but if it's got 2 piece jaws (master jaw type)the cost of new ones are about $400 and you still have might have wear in the scroll which will effect the accuracy.
    Just my $.02
    Scott
    Mar 2009
    Alabama, U.S.A
    610
    14
    Tom, just went through this same thing with an old cushman. World wide chucks said the rebuild would outweigh the cost of a new one if it is a smaller chuck. So I inquired about replacment jaws, been over a week and they have'nt replied to any of my follow up e-mails. Grizzly and CDOC tools have nice new ones, but CDOC is cheaper. m71
    Feb 2009
    Hamburg,NY,U.S.A.
    392
    11
    Smile
    Tom, I made inquiry quite recently at Worldwide Chuck regarding my Cushman 3506 6" 3 jaw. Cheaper to buy new. BTW, my chuck is in pretty nice shape, simply missing the 2nd jaw set. So I'll keep what I've got & watch Flea Bay. Who knows, maybe one fine day a jaw set will turn up.
    Ed
    Apr 2009
    20
    Quote Originally Posted by phantom71 View Post
    They got back to me yesterday said that no replacement jaws available but they could sell me a new one for $850.00
    Has anyone been able to resurface the faces on the jaws, the probelm of mine is someone let a threaded shaft spin in the jaws and sort of threaded the surfaces. any body got any thiughts on how to fix.thanks TOM
    Aug 2004
    Virginia
    1,965
    147
    664
    Hi Tom, This is kind of a sticky wicket as they say. Most of the time people are trying to fix run out on a worn three jaw chuck and the results are mixed. I have tried it myself on a few occasions and again had mixed results. In your case it may work because your scroll may not be worn and the jaws as you said are just "threaded". The problem with trying to repair a three jaw with a worn scroll is that it may work fine in that one position where you ground the jaws but when you get to another part of the scroll it will have run out again. In your case you might be able to grind the jaws with a toolpost grinder if you have one. Clamp a ring in the jaws to take up slack before you grind or you will cause more harm then good. I had one that was so whacked out I could not do even that. I ended up making a set of soft jaws for it to solve the problem.
    Apr 2009
    20
    My son was able to buy me a new old stock 5 inch 3 jaw Bison for $75.00 boy am I blessed, THANK YOU LORD, TOM
    Apr 2009
    20
    Quote Originally Posted by tom kilgore View Post
    Well we used the backing plate off my old cushman chuck machined it flat cut a shoulder for the new bison,drilled and tapped 3 mounting holes. mounted it and it works great.
    regards tom
    Nov 2008
    Jeffersonville, IN
    36
    Tom,
    What are you going to do with the old chuck, or what is left of it?
    Ed
