Idflatwater
- May 20, 2017
I traded into a 10L for pretty cheap. It came with two 3jaw chucks and one 6jaw chuck. Most all of my machine shop knowledge cames from a class room but I didn't know they made a 6jaw. How useful are they?
Beg to differ, used six jaws almost exclusively for years, I love them. Except for costing twice as much for top jaws and taking twice as long to change, they work super.Mostly, people / hobbyists like to show off their fancy six jaws like a gun slinger would flash his holstered side arm.
Most practical "six jaw" applications include removing three of the jaws. ;-)
UNLESS...thin wall tubing is the work piece.
So basically it is just a better way to turn round thinner walled projects? It'll do the job of a 4jaw except four square projects?
.0002" over wires good enough for you ? Did that all day long ...If the 6-jaw is an adjust-tru or similar, it might be possible to get most of the runout down to a minimum, but it will probably never dial in perfectly like a 4-jaw.
Discount Hewland replacements, Webster Gear. 72A5 Heald. Over wires. Alina tenths indicator, 1 1/2" face. Indicate each part. Federal bore gauge to check the finished parts, Etalon ring gages to set the bore gauge. Had Ingages too, but they were not as handy to use. Accurate, for the time.I have to admit that seeing a response from China that they're 6-jaw chuck is within 2 tenths makes me wonder if I'm being trolled...
That's better than I actually need, I usually work to a .001", but happy that it works for you.
Why would you do that ?I recently bought a 4 jaw scroll chuck ...
I'm trying to think of an occasion ...They are handy to have, not necessary, but handy on occasion.
QT :[ Steve: I recently bought a 4 jaw scroll chuck with a semi-finished back plate from China. Upon receipt, I finished the back plate perfectly (within .0002). I then mounted the chuck and discovered the run out was always between .006 and .015, never better. The fault was that the scroll itself was not concentric with its bearing. I then threw the brand new chuck in the scrap pile.] What a shame when a new thing has to go scrap.
I would think the entire front works of a chuck might be made together so might run fairly close.. then the flit over and manufacture of the back might be set error to flat and error to center. so the fix might be to tool or grind the back off a held part or off the front...Still it sens buying a china or the like can be buying a project.
For the OP the 6 jaw like worth 100 to 300 if off brand running .005.. could perhaps shim back to see if it might repeat and not wobble too bad.. then tool the back it that proved a goo choice... or just keep the ,005 as good enough.
Notice
