mjr6550
- Oct 7, 2012
- Lansdale, PA
My restoration is progressing slowly. Most parts are painted, so assembly is not far off. I have just turned my attention to the horizontal drive. I removed the shaft and found that it is badly scored. The bearings (cast iron-not bronze) are scored pretty deep on one side also. I question whether there is enough material to bore out the casting to add a bushing or bronze bearings. I also do not have a working lathe to do this. I thought about turning down the ends and making slightly oversized sleeves. Any suggestions, other than buying a new drive unit.
Regarding the shaft, I assume making a new shaft from 0.875 material would be the way to go. If I went with the sleeve idea I could assemble the lathe with the old shaft, lube it well, and use it just to make the new parts.
With a new shaft I also would need to make a hole for the taper pin. I would appreciate any suggestions for this also. From what I read I could go with a tapered drill and reamer (a bit expensive), step drill the hole and buy just a reamer, or fabricate a D-reamer.
I appreciate the help you guys have given me and other novices. I have also found the resources for the rebuild manual, new compound and cross-side nuts, and oil to be very helpful.
Maybe I'll have a working lathe by the end of the year!
