Zeusizme
- Mar 17, 2013
- Western PA
Pardon my ignorance but I can't seem to find anything on the net about what cross feed nut to use on a large dial. My compound and cross feed nuts both need replaced and they are both large dial. Will the regular cross feed nuts work? Or do I need a special nut because of the large dials? Someone in the past has monkeyed with the cross feed nut since it isn't the same style that a 9" takes, plus a bushing was installed in the cross slide and threaded for a 3/8" bolt that threads directly into the bronze cross feed nut. I plan on removing the bushing and replacing what I need to to correct it, but what parts are in the cross feed nut? Anyone have some pictures they can share? Thanks
