Stuff like this ends up being a judgment call IMO. On the one hand you can oil it the same as the factory recommended when it was new, on the other hand you can oil it like the newer built machines.
I've used the Roy Dean lube ever since I had the back gear seize, but to be fair, I changed our practices with how we oil our Heavy 10 after that happened. We used to just oil it with whatever can of machine oil was nearby and seemed appropriate and it got oiled whenever the operator thought it needed it. After the stuck gear, I went back to the manual we had and looked up which oils were recommended for which part of the machine, how often it needed it, and got it it's own set of oil cans. Heavy way oil for the ways, Light spindle oil for the spindle bearings, Roy Dean grease for the back-gear, and Medium way oil for everything else. The operators are in charge of the "daily" lube tasks, and the weekly/monthly/yearly tasks are scheduled with the rest of the shops maintenance routine so they don't get forgotten.
