Long Lonesome
- Dec 12, 2005
- Arkansas
The SB 9C that I bought last week has a Century 1/2hp motor that I don't think is the original. It is wired through an old brown house wiring wall switch that is attached to the metal stand with a clamp bracket that obviously is meant to attach to the lathe bed, possibly to hold the original drum-type switch.
My question is, did the original type 110v 1-ph motor have the capability of running in reverse, and can this motor be wired to have reversing if the drum switch is used?
The specs on this motor are:
Century Elec. Co.
CSH-81-BH4-3AE
1/2hp 115/230 60cy
1750 rpm 7.0/3.5 A
Ser. No. AA1 Code L
Open 40deg.
This is an impressive looking motor, runs smooth and quiet, but looks a bit large in relation to the lathe. One negative thing is, because of it's physical size, an adapter plate was made to shift it to the right for belt alignment. Also, it is "laying on it's side" to be mounted on the plate, which is vertical. This puts the shaft oil cups on their side and prevents them from holding oil. I wonder if the thru-bolts can be removed and the end caps (with oil cups) be rotated 90 degrees?
Thanks in advance for your replies,
Greg
Century Elec. Co.
CSH-81-BH4-3AE
1/2hp 115/230 60cy
1750 rpm 7.0/3.5 A
Ser. No. AA1 Code L
Open 40deg.
Greg
