Another Stuck Chuck Back Plate to Spindle on SB 10L
Results 1 to 14 of 14
    Sep 2017
    Ohio
    12
    Default Another Stuck Chuck Back Plate to Spindle on SB 10L
    I've about tried everything. Penetrating oil, heat and it won't budge. I even tried inserting a bolt into the chuck and used an impact wrench. Any other ideas or fool proof methods?
    Oct 2015
    Virginia
    270
    10
    44
    You tried penetrating oil, but did you try Kroil? Kroil has worked for me when other products like PB-Blaster, Liquid Wrench, WD-40, etc haven't. Try heat and then shocking with ice cold water.
    The good thing a 10L spindle is cheap and only takes a couple hours to swap one.
    Some reading:
    http://www.modelenginenews.org/techn...tuckchuck.html
    http://www.lathes.co.uk/stuckchuck/
    How to Remove a Stuck Chuck -- Tutorial
    http://bbs.homeshopmachinist.net/thr...uck-back-plate
    Dec 2008
    New York
    7,978
    2112
    just remember rotation stop pin and even back gears are only so strong. if you use 24" wrench often you will damage something if not careful
    Jan 2014
    North Carolina
    338
    10
    86
    You may need penetrating oil AND vibration in order to pump the stuff into the threads. Liberally apply the Kroil, rattle it with your impact wrench, and then go away for a while---maybe even a day. Repeat Kroil and vibration. It will come apart eventually. Just DO NOT use the back gears to lock the spindle as you apply torque to loosen it. If you knock a few teeth off the back gear set, the stuck chuck will seem like a very minor problem by comparison.
  5. Likes thomasutley liked this post
    Sep 2017
    Ohio
    12
    I have it out of the lathe now for restoration so I will get some kroil and let it seep in there for a week or so and try again. Thanks for the input.
    Sep 2010
    moscow,ohio
    4,547
    451
    1354
    What never failed for me was to clamp about a 4 ft bar in the chuck, position it so it is sticking straight out, engage back gears but do not pull the pin.
    hang a weight on the end of the bar,protect the ways so the bar doesn't damage them when it breaks loose,apply a little heat and spray with penetrating oil.
    Come back in a couple days.
    if that doesn't do it, back plates are cheap..Remove chuck from plate and use the lathe to machine it off.
  8. Likes Rudd liked this post
  9. #7
    Jul 2003
    savannah, jaw-ja
    1,515
    797
    303
    Quote Originally Posted by iwananew10K View Post
    Words of wisdom right there. I spent days screwing around trying to save a backplate and risking busting an expensive hard to replace gear. Once I decided to cut it, Boom, 10 minutes and it was over.
    I recall using a parting tool - with known spindle diameter and known OD of backplate stub, I knew how far to feed in before hitting spindle. I got close, heard a satisfying "pop" and the thing came off easy. I believe I made my cut near the rear of the threaded area, I was actually able to use the cut off remains of the plate to mount the chuck and bore/thread the new plate. (yes, I have the 1 7/8" x 8" oddball spindle)
    Clarification, this is one time the old Armstrong tool post and a LH(?) parting tool holder came in really handy)
  10. Likes Ken-Bergen, iwananew10K liked this post
  11. #8
    Sep 2010
    moscow,ohio
    4,547
    451
    1354
    ^^^ heck yes! most backplates have too much hub anyway.
  12. #9
    Aug 2017
    Illinois
    91
    55
    29
    My first “lathe’ sat outside for a few years in pieces on the ground in the dirt, rain and snow of Wisconsin. When I showed up to buy it, it was in a wheel barrow.
    I almost start twitching now at the thought of getting the quill out of that SOB’s tail stock. The first week of multiple daily sessions of heat and Kroil and tapping on it wasn’t too bad, but by the end of week two when it finally came loose… I was only minutes away from a nervous breakdown!
    I was used to the typical aggravating stuck and stripped bolts, and even the occasional impossible pulley or centrifugal clutch, but this little quill was like playing in the major leagues, and it pummeled into my very being a whole next level of patience.
    Along with heat and Kroil that kind of next level patience and persistence is all I can suggest.
    Stick with it, it'll come apart one way or another... someday.
  13. #10
    Aug 2014
    bainbridge island
    700
    130
    172
    heat the chuck and spindle uniformly, let the heat soak in. maybe 200F, 300F.
    put an ice cube in the spindle while applying torque to the chuck.
  14. #11
    Sep 2017
    Ohio
    12
    Thanks for the suggestions. When I get it back together then I will try the least destructive methods first until I get pissed and finally cut it off! These are standard threads,not reversed...right?
  15. #12
    Apr 2017
    179
    23
    75
    Correct. Normal right hand threads. The side of the chuck closest to the operator needs to spin Down to loosen.
  16. #13
    Oct 2015
    Virginia
    270
    10
    44
    I'm just going out on a limb here since we don't have any pictures, but are you sure you have a direct thread spindle and not a cam-lock or a L-00 mount?
  17. #14
    Nov 2008
    Madera county california usa
    1,995
    16
    455
    From old school instructions....
    Place lathe in lowest direct drive speed without any gears engaged meaning only belts.
    Put something in the chuck and tighten all 3 places.
    Put chuck key in and have it straight out toward front
    Rest a 2 X 4 across it
    Get the largest hammer you can find and just let it drop on the 2 X 4 and it should bust it loose.
    Rotate chuck and smack all positions.
    Sent from my SAMSUNG-SGH-I337Z using Tapatalk
