Blob
Hot Rolled
- Apr 7, 2007
- Scotts Valley, CA
I have a Jacobs Rubberflex collet chuck for my 10K, and have a question about runout. With the chuck mounted on the spindle, the taper where the collets seat runs true within tenths, nearly perfect, but some of the collets exhibit quite a lot of runout when holding work, others are good to very good. None are as good as the taper itself. Any idea why this is happening? Do the collets wear out? I know Jacobs no longer makes these, and I have no idea how old my set is. I have made every attempt to be sure the collets are clean inside and out, as well as the chuck taper. The rubber on the collets appears in good shape and is still flexible. Any info will be appreciated - thanks.
