xplodee
Hot Rolled
- Oct 14, 2013
- Allentown, PA
Hi All-
I have a 10L with taper attachment and I am in the process of installing thrust bearings. I already have the sliding lead screw assembly done and am no preparing to do the handwheel assembly.
My question is: is the brass bushing that sits between the handwheel and the sleeve critical for this mechanism to work best, or can I just pre-load the graduated dial instead, and omit the brass bushing entirely from the design?
I will probably just go with the brass bushing because it seems a better way of doing it, but i wanted to ask the group about it first.
Thank you,
T
Thank you,
T
