shearspeed
- Feb 7, 2010
- Kingston, TN
I had my heavy 10 hooked up to a VFD and it would only go foward operating through the VFD. I wanted to hook it up to the barrel switch so I can use reverse. Help me out here, do all three wires go on the same side of the barrel? The way I see it the switch has cross over wiring on the barrel fo the forward position and the reverse wire looks to be on the same side. It worked before now it doesn't, I had a rep for tb wood walk me through it changing the codes. Do I have it wired correctly or not? porbably not explaining it right.
Dan
Dan
