Rick_B
Stainless
- Sep 16, 2011
- Winston Salem, NC
Good evening folks - here's the scenario, I'm starting with a 3" diameter piece of material in a 4 Jaw chuck. Then I'm offsetting the center of the material by a 1/4" in the X direction. Then I will be drilling a 3/4" hole followed by boring that to 2" diameter. This work will be done on a wide bed SB 9" with a large spindle.
So now the question - I need to part off a 7/16" piece of the drilled and bored material. I think there may be at least two methods
1. leave everything off set in the 4 jaw and part off. This will result in interrupted cuts on the external surface for a large part of the cut.
2. Put the 3" diameter back on center and part off - interrupted cuts internally for a large part of the operation.
It seems that option 1 may be the best way but I thought some expert input was called for. Any thoughts or other potential methods?
Rick
Rick
