As I am re-assembling the cross feed on my lathe after terardown for cleaning I see that there are a pair of small holes drilled through the bushing (item 20 on form 911J) that threads into the saddle to support/guide the cross feed screw. The holes lines up with the oil hole in the top of the saddle, but only if I back the bushing out about 20 deg after it bottoms out. I see the same holes in the similar bushing on the top compund (item18 on form 948D), but for that bushing, if I line the hole up with the oil hole (at 12:00 position), the zero marker scrribed in the bushing lands at 11:00 instead of 12:00.
My question: are the holes supposed to line up at 12:00 so the oil fed into the oil port drips directly onto the cross feed screw where it sits inside the bushing, or is the oil supposed to roll down the top of the bushing and eventually find the cross hole?
Chris
Chris
