clr8ter
Cast Iron
- Mar 23, 2013
- South Central NH
I am still having troubles boring holes on my lathe. I have tried various tool angles and such, but no luck. The bit tends to walk to the inside, and leave a really nasty finish.
Here are the details;
Heavy 10
chinese boring bar set, carbide, the type used for non-ferrous metals. (I'm boring aluminum)
Slowest feed speed, or fed by hand
Fast spindle speed
tool as close to on-center as I can see
chinese quick change tool holder, AXA
Is the end (face) of the cutter supposed to be square to the bore? or is the cutting edge of the cutter supposed to be parallel to the bore? Cutter angled up slightly into the work, right?
Admittedly, I'm boring a very small hole, less than .500", and using the smallest boring bar in the set. I don't see any clearance issues, and everything is tight.
I don't really see any other way to get non-standard holes. I cannot go out and buy a drill bit or reamer every time I have to drill a hole. But this just isn't working...
Heavy 10
Fast spindle speed
