Off-kilter
- Jan 11, 2013
- Somerset Ky, USA
Hello everyone! I just purchased a SB 13 with a broken headstock. It belonged to a boys camp and the machine had been knocked over on its side. Almost all of the broken pieces are present except the flat belt change handle and linkages in the under drive cabinet. I think it is a 1941. Haven't taken the time to check the numbers. It has a single lever QCGB and large dials on the feed screws. I think worse case senario, I can weld the headstock without compromising accuracy but I would rather replace it. It looks like the heavy 10 and the 13 are almost identical. I am assuming they are not. Is the 10 headstock a possibility or should I repair or even replace the casting? The lathe will not be used frequently but I do plan on restoring it if I can get the headstock worked out. If not I will scrap it, keep the motor for my shaper and sale the parts that are good. Any help is greatly appreciated!
