Can two people safely remove Heavy 10 from a pallet?
Page 1 of 2 12 LastLast
Results 1 to 20 of 32
    May 2010
    TX
    108
    Default Can two people safely remove Heavy 10 from a pallet?
    I am ready to finally remove my lathe from the shipping pallet it came on. I got it wired up with the new motor / adapter plate to adapt a 75u to 56 frame, cuts fine too. I know these things are dangerously top heavy so I am requesting aid.
    Do you think two medium sized guys could remove this off the pallet (about 5" above the concrete) ? Or would it be better to get a little more help or rent an engine hoist?
    The machine is already about 3 feet from its intended spot. I dont mean to be a cheap [email protected]! but I can rent an engine hoist for $30 for a few hours. At the same time I dont want to spend time running across town and bring it back for 10 minutes of use.
    If I remember right the shipper said it weighed around 600 lbs loaded up.
    Feb 2006
    Seattle, WA
    581
    9
    My Heavy 10 is close to 1000 lbs. I wouldn't think about trying to move it without an engine hoist. Not that I could if I wanted to. There are always other creative ways to lift and move it, but you do so at your own risk. Maybe set the pallet on fire?
    May 2010
    TX
    108
    Quote Originally Posted by Waterlogged View Post
    I had actually entertained that idea but I would rather rent the engine hoist than pay a divorce attorney.
    Feb 2005
    Columbus, OH
    277
    7
    Default 2x6s & a chainfall
    check out:
    Moving a Bridgeport Milling Machine - Recreational Rigging | The Steampunk Workshop
    2K+ lbs CNC by one guy unload from trailer
    Sep 2004
    Rugeley UK
    949
    20
    93
    Get some pieces of steel flat say 2" wide by 1/2 to 5/8" thick, a crow bar and lift one side of the machine at a time and slip the bars underneath, then slide the machine down the bars to the floor like on railway lines. I have done this many time with machines up to 2 tons, take it steady and no heroics.
    Peter
    Mar 2004
    Lawn Guylin, Noo Yawk
    2,692
    20
    50
    Along Peter's line of attack, support one corner of the machine with a jack, then saw away that section of the pallet. Replace the missing corner with a few loose pieces of 2x blocking.
    Repeat with the other three remaining corners. When the pallet is all gone, and the machine up on four seperately blocked corners, jack each corner as before, this time removing one piece of 2x at a time and lowering until the machine is eased down onto the floor. Tedious, but you can do it yourself.
    Feb 2004
    peekskill, NY
    23,601
    3843
    Another approach, slip several pipes under the bed, and put a strong high school
    student on the end of each pipe. Say 8 football players in all would do the job.
    Aug 2008
    Sussex, England
    3,046
    9
    596
    Although Peter is right in that this and many other slider / lever / et al ideas work well and perfectly safely if you know what you are doing and have some experience of hefty shifting work its a different matter for the inexperienced.
    If its a leg & pedestal version rather than a cupboard base type sliding isn't an option, far too easy to bust the legs.
    Get the hoist, not forgetting good quality lifting straps or chains (mind the lead screw!). That way its straight forward 10 minute job (so it'll take 2 hours then). Even with experience the "improvised" methods have a nasty habit of getting very hard half way through and taking much longer. I've done 6 machine moves the knife and fork way, next time I'm getting the gear in.
    Clive
    Mar 2004
    2,692
    20
    50
    Talking
    Quote Originally Posted by jim rozen View Post
    And have them stand on the pallet, so they dont have to bend over to lift the lathe.
    Mar 2010
    Utah
    648
    44
    36
    Default engine hoist
    spend the $$ and get the engine hoist {2 ton} you will be glad you did......
  11. #11
    May 2010
    TX
    108
    Quote Originally Posted by packrat2 View Post
    It's looking like that's the only way to go.
  12. #12
    Feb 2008
    Hawaii
    208
    5
    25
    I would consider the cost of the engine hoist as cheap insurance against someone getting hurt or damage to the machine.
  13. #13
    Jul 2009
    AZ
    5
    Get the hoist, I speak from experience. if you move it without the hoist you will increase the risk of injury. I've spent nearly a year recovering from a low back injury moving my Logan 12", the lathe & cabinent cost $900, Ive spent close to $7000 in therapy, & hospital bills. I don't have full range of motion in my left shoulder yet lots of nerve damage was the end result.
  14. #14
    Feb 2004
    Traverse City, MI
    3,264
    61
    102
    Have you considered leaving it on the pallet? Unless you are short, the added height might be easier on your back. Both of my lathes are blocked up higher that they were made. Gary P. Hansen
  15. #15
    Sep 2009
    Wisconsin USA
    68
    5
    I bought an engine hoist.
    I can't imagine moving that lathe without one. Even with a hoist, I'll bet it takes 2 guys.
    Mark H
  16. #16
    Jan 2010
    Indianapolis, Indiana, USA
    5,474
    2426
    925
    Quote Originally Posted by AR15M4 View Post
    Sorry to hear of your pain and injury, I have made it to 54 without serious injury simply by refusing to let others use me as their heroic measure.
    And that includes me refusing to be my own heroic measure.
    Spend some money, spend some time, come back another day, etc.
    One thing some of the members are overlooking is the 'telehandler' or 'boomlift' forklift that comes on large 'tractor' tires. YOU CAN DRIVE IT ON PUBLIC ROADS. The smallest is about 5,000 pounds capacity, you could literally put your item on a second story balcony.
    I was checking into one, asked about delivery, the answer was "if you want, drive off our lot, down the road to your location".
    About 200 bucks for the day, some rental agencies prefer to be closed on Sunday, so pick it up Saturday morning, return Monday morning and pay only one day rental. Here in Indy that would be Arrow Rental.
    Cheaper than the emergency room.
  17. #17
    May 2010
    TX
    108
    Quote Originally Posted by garyphansen View Post
    I figured this was the last way to leave it, but I don't know anything about this.
    The height it is at is not a problem, I was just concerned that this would possibly be robbing accuracy and cause it to be unlevel do to the variation of the garage floor alone, then the difference in height of the wood pieces across the entire platform.
  18. #18
    Feb 2004
    Baltimore, MD, USA
    3,861
    242
    504
    A 10L isn't much work to move.. One guy to move the headstock, two guys to pick the bed up off the base & move it. If its a pedestal base, move it w/ a handtruck- if a cabinet then crab it off the pallet onto some 2x4's, then onto pipes if crabbing doesn't work on the floor.
    A shop crane will be handy but if you want to use it you'll still have to work the cabinet over to the corner before you can get a reasonably good pick off the pallet.
    Greg
  19. #19
    Aug 2008
    255
    Out of all of these ideas two are excellent--Renting an engine hoist and setting the pallet on fire.
  20. #20
    Dec 2009
    new york
    462
    7
    Quote Originally Posted by John Poyser View Post
    John I am sure that you being a man of machinery as I am will understand that to move a heavy 10 on a cabinet or a pedistal is to me a piece of cake. I guess I am very fortunate to have the strength to do it alone because I have for many years thrown those machines around like nothing lifting the tail stock end up and swinging it off the pallet and while I lift the head stock end have one of my kids pull the pallet out. At 46 years old I feel great but maybe later in life I will feel pain.
