so I recently purchased and began to restore to working condition apparently the second oldest 15 inch (37-E) recorded to date, and the 8th confirmed [of that model] date, shipped from its factory 12-30-14.
Here's photos, more as I go along:
SBL37
"Thats the view from the wrong side."
Its natural lighting, better when I get things arranged.
"Oh my god, its outside."
Thats where I found it, at least now its under a sturdy slip cover wrapped in bungee cord so as not to blow away.
"He doesn't know what hes doing, he should do this, that, or the other thing"
Right on the first part at least, but you'll get over it. I don't have nearly the time I want to devote to this project, and Ill ask for help as I need it, thanks.
"He doesn't have the apron/composite rest, that chunk of scrap was/is a huge waste of cash"
I do, the apron is in my local machine shop having a new worm gear cut. The rest I just got back from the machine shop as I didn't have the tool to free it from its oxide cake. So far the entire project is set to run me 400 USD, but I know there is more cost yet to find.
Now to the meat:
Everything that's supposed to move, moves. Save the motor, which I'll cover in a second, and possibly the handle that changes the requirement of back-gear engagement for running slow speeds, I didn't know that existed until after I had walked away from it the last time.
The current motor is 3 phase 120vac, at I think 1 hp, though I'm not in front of its plate at the moment. It does not move. I have yet to tear into it to see whats binding. I do have a replacement 1 phase 120vac 1 hp assuming I can pry the water pump off of the front of that.
I have only the one set of change gears, measurements or where to find them for other thread pitches would be appreciated. No, I don't know what pitch I have now.
The forward or maybe reverse gear for the feed screw is missing, I know I can do the math to find its size but if someone has those numbers, I'd appreciate that too.
More to follow
SBL37
Now to the meat:
More to follow
