I have a 13" SB in good shape. Recently the cross feed screw jams, worse under power. I must release the power, back off and then reengage. I first thought that the problem was in the lever clutch on the apron. I took that apart and cleaned it. The clutch shaft was slightly bent but I was able to straighten it. That was not the problem. I have checked the gears in the feed train and do not see damaged or missing teeth. It is not in the feed screw or the brass nut because It happens even with the nut disengaged. Any thoughts?
Gordon
Gordon
