jhmiii
- Aug 4, 2016
- Carmel, IN
I am currently in the midst of rebuilding a South Bend 9a and have discovered that the threads on the handle end of the cross feed screw are quite mangled. My initial thought is to reduce this threaded portion of the screw, loctite or solder on a cylinder, and cut the new threads in this cylinder. Then after installing the handle, drill for the lock pin. Does anyone know the thread pitch of the original and the length of the threaded portion?
I am also open to any other suggestions you may have for this repair.
John
John
