Jeff_G
Hot Rolled
- Aug 25, 2004
- Granite, MD USA
Hi All,
I'm in the process of cleaning up my "new" 1950 model 9A. Pulled the crossfeed screw and after cleaning and re-insertion, I notice that there's some axial play between the screw and the saddle. The collar that threads into the saddle casting is all the way in.
Is there an adjustment hiding here somewhere? I didn't remove the crank from the end of the screw - appears to be a drive fit with axial pin to prevent rotation. Do I just need to drive the crank a bit farther onto the screw?
Thanks for you help,
Jeff Greenblatt
Jeff Greenblatt
