jholder
- Aug 24, 2014
- Huntsville, AL
I apologize for the somewhat confusing title, let me set the scene and maybe it will make more sense. (For the record SB 10L from the mid 40s)
So yesterday I thought I'd try my hand cutting a taper. Set everything up, only to find that I could barely move anything laterally once I had everything tightened down. Did some research online and a lot of posts indicated that it may be as simple as years of dirt and dried oil gumming things up. I pulled the taper attachment off and gave it a good cleaning, and sure enough, it all moved together as I thought it should. While I had everything apart (and since I had recently received the proper a/b/c and way oils), I also decided to put the correct oil in the reservoirs/oil holes etc.
Anyway, so I put everything back together, and tried it out. Everything moved laterally as it should but the cross feed knob simply didn't feel the same anymore. It felt like the entire unit was dragging when I moved it in and out. I played with it for a bit, looking for some obvious reason, and ended up removing the taper attachment (in case there was friction and it was somehow affecting it) so that the screw was basically free. This provided *some* relief, it still felt as if something was too tight(?) or had no lubrication. I noticed that the machined surfaces (even with fresh oil) had sort of a black discoloration to them. In fact,running my fingers down them, the oil that was left on the machined surface almost felt gritty.
The only thing I can really think of is that my introduction of new oil has somehow knocked loose 70 years of built up grime and swarf that had been stuck in the oil passages? Since I'm this far along I thought I might was well pull the cross feed off and give it a good cleaning anyway, but was looking for other input since it's sort of a PITA.
I'm not sure what else I could have done that would have affected the cross feed this way. Can you guys think of anything I missed?
