The way my motor came wired only allows the lathe to run in forward regardless of switch position. I am trying to re-wire the switch / box to be able to properly run in reverse. I did some searching but the drawings I found did not make all that much sense. Can anyone with the same switch/motor help out?
Also: am I supposed to have a connection box alongside the switch? My last lathe had all the wires from the motor / plug wire directly into the switch without another box.
