Hello Steve
Do you have the lathe Im talking about? How sure are you that is a MT5 spindle. I keep hearing that it is a proprietary taper that southbend made. I guess Ill just have to measure it when I get the lathe put back together. I was hoping to hear from someone that specifically has this spindle and what they use.
thanks
Cease "hearing", start googling. Most things SB were "volume production", highly unlikely you have an R&D one-off. Other folk HAVE these.
Packrat mind sez you'll find a 5 1/2 MT. Which shouldn't exist, but SB was not the only one to need it, so no, you won't find MT drill shanks for it, but yes collet adapters and HS adapters to #3 or #2 MT for use of inexpensive stock DC w/o need of an inch or two greater hang-out.
Which, BTW is the penalty I pay when using an easily-purchased "proper" #12 Jarno centre in a 10EE instead of THEIR stub adapter. Loss of nearly 2" of already-scarce 20" c-to-c daylight.
Now - if measuring is difficult - and it IS, because you will almost certainly not be on the published "big end" gage line, just purchase something low-risk CHEAP.
With a 5MT drill press, and one lathe that uses 5MT in BOTH HS & TS (Cazeneuve, not SB), I have these goods aplenty. Sleeves are cheap and cheerful. 5 MT drills? Don't even ask!
A 5 MT to 4 MT or 5 MT to 3 MT sleeve, even if Chinese made so long as brand-new, should do yah as a test for fit.
A "thought to be right" SB collet adapter, used, you can easily sell-on if not a match for your spindle.
